Hi everyone,
I am using this REST API: https://www.dynatrace.com/support/help/dynatrace-api/environment-api/topology-and-sma[…]e/custom-device-api/report-custom-device-metric-via-rest-api
to report a metric for an existing custom device. Instead of reporting the custom metric for an existing device, this api call creates a new custom device and attaches the metric to it.
This is a sample call that I am making:
curl -X POST \
https://cto43873.live.dynatrace.com/api/v1/entity/infrastructure/custom/idOfmyCustomDevice \
-H 'Authorization: Api-Token dt0c01.APITOKEN' \
-H 'Content-Type: application/json' \
-d '{
"type": "Azure Virtual Network Gateway",
"series" : [
"timeseriesId" : "custom:my.custom.metric",
"dataPoints" : [
[ 1654695594547, 20 ]
