# print to Next line of placeholder in email body
**URL:** <https://community.dynatrace.com/t/print-to-next-line-of-placeholder-in-email-body/40060>\
**Category:** Open Q&A\
**Tags:** problem-notification\
**Created:** [June 5, 2023, 9:21am UTC](https://community.dynatrace.com/t/print-to-next-line-of-placeholder-in-email-body/40060 "2023-06-05T09:21:18Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![SaiVenkatesh](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/saivenkatesh/32/31730_2.png) [@SaiVenkatesh](https://community.dynatrace.com/u/SaiVenkatesh)\
**Post date:** [June 5, 2023, 9:21am UTC](https://community.dynatrace.com/t/print-to-next-line-of-placeholder-in-email-body/40060/1 "2023-06-05T09:21:18Z")
</div>
I am using multiple placeholders in email integration ( body ) & i wanted to print them in separate lines in the email body. Is there a possibility ?
**Author:** ![avdveen](https://avatars.discourse-cdn.com/v4/letter/a/ed8c4c/32.png) [@avdveen](https://community.dynatrace.com/u/avdveen)\
**Post date:** [June 6, 2023, 9:00am UTC](https://community.dynatrace.com/t/print-to-next-line-of-placeholder-in-email-body/40060/2 "2023-06-06T09:00:25Z")
</div>
Hi [@SaiVenkatesh](https://community.dynatrace.com/user/55643)
It is possible to put them on separate lines, as long as you use HTML format for the problem notifications.
You can use the standard HTML line break code **\<br /\>** for this in the email body field - for example:
```auto
{ProblemDetailsHTML}
This is a new line.
This is also a new line.
This is yet another new line.
If you only put a single **\<br /\>** it will break to the next line, but not leave a space between them like in my example.
