I am trying to configure a HTTP monitor from a private location where the URL is…http://example and the full url is http://example.corp.example1.com/sites/it/home.aspx.; problem I’m having is if you browse to the full URL I get this error…
Server Error in ‘/’ Application.
The resource cannot be found.
Description: HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable. Please review the following URL and make sure that it is spelled correctly.
Requested URL: /sites/it/home.aspx
If I setup a HTTP Monitor on a private location for http://example, I get an unknown host error.
How would I set this up for a HTTP monitor? Is there a way to setup a DNS suffix in the synthetic configuration? By the way, this is a Sharepoint site.
