Please let me know anyone has written python script to export Problems data from API V2.
API V2-> Problems → List problems observed within the specified time frame.
Challenge I faced : with evidenceDetails field we can export only 10 problems once, suppose I have 1000 problems in last 1 month then I have to run this API 100 times manually with nextPage key.
We have python scripts to export Problem data as well but haven’t found a efficient way to parse nextKeyPages. Will definitely be taking a look at what you’ve set up and improve ours.
please is it possible to add Problem selector filed also , I want to export problems data based on MZ names so that we will have problems count for each application in last 1 mont.
Management zone ID: managementZoneIds(“mZId-1”, “mzId-2”).
Management zone name: managementZones(“value-1”,“value-2”)
