Problems retrieving properties in the workflow
I am trying to get a metric ingested into Dynatrace to generate a property in the event for the technology dimension it is ingested into. The problem is that when I add it to anomaly detection, I believe it can be seen in the user interface for issues, but it is not displayed in the event, so I cannot subsequently extract the data in a workflow.
I have attached screenshots to make this easier to understand.
