Puppet Install for Dynatrace
Is there a puppet script available for OneAgent install?
thanks
Moses
Yes, see: https://forge.puppet.com/dynatrace/dynatraceoneagent
Do you know if there is an option to add a host group to the puppet module?
hi @Michael K.,
After installing OneAgents with Puppet have seen errors like this in Dynatrace GUI for one of the Host ( Windows OS)
Have disabled the Automatic updates of OneAgents post seeing this error. Any idea how to overcome this?
Thanks!
hi @Nicoe W. if you are using Foreman to manage your puppet modules then you can classify/Seggregate the Host Groups.
