I am busy migrating one of the Python v 1 plugins to V2. As part of the packages I need to upload I use pymongo (Client Challenge) but it is failing with
{ “error”: [ “Could not find a version that satisfies the requirement pymongo (from mongodbreplication) (from versions: none)”, “ERROR: No matching distribution found for pymongo”, “” ],
All the packages are there as seen in the lib directory and the setup is showing what is required. The issue seems to be with that because I am compiling from my windows machine it is only downloading the pymongo-4.6.3-cp310-cp310-win_amd64.whl. My activegates are windows so in this case all I need is it to upload this package to the environments.
I tried adding just win_amd_64 to see if that work and still fails.
So how do I force it to either only upload the windows version or download both windows and linux version.
