Hi Folks,
Has anyone used DT as a quality gate at a native mobile app CI/CD pipeline?
Do you have any ideas regarding this topic? Do you have any use cases?
Thanks in advance.
Br, Mizső
Hi Folks,
Thanks in advance.
Br, Mizső
@Mizső were you able to get any information on this that you could share with the community?
Hi @ChadTurner,
Unfortunately I have not received any ideas ans use cases. :frowning:
Best regards,
Mizső
@Mizső I assume you need to have a quality gate for the app itself, not for the backend. As with other quality gate concepts, you need to perform some sorts of automated testing (there are many tools in the wild for that). Then I’d just recommend having properly configured Dynatrace for the mobile app (user actions, error detection, etc..). and for the quality gate evaluating metrics such as apdex, reported errors, network errors etc.
