# Questions about log monitoring constraints
**URL:** <https://community.dynatrace.com/t/questions-about-log-monitoring-constraints/31660>\
**Category:** Logs\
**Tags:** log-monitoring-class\
**Created:** [June 1, 2021, 7:26am UTC](https://community.dynatrace.com/t/questions-about-log-monitoring-constraints/31660 "2021-06-01T07:26:24Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![parksm](https://avatars.discourse-cdn.com/v4/letter/p/d6d6ee/32.png) [@parksm](https://community.dynatrace.com/u/parksm)\
**Post date:** [June 1, 2021, 7:26am UTC](https://community.dynatrace.com/t/questions-about-log-monitoring-constraints/31660/1 "2021-06-01T07:26:24Z")
</div>
Hello, I am a Korean engineer.
> **[Add log files manually (Logs Classic)](https://docs.dynatrace.com/docs/analyze-explore-automate/log-monitoring/acquire-log-data/add-log-files-manually-v2-classic)**
> Learn how to manually add log files for analysis.
Why are there differences between \*.log files and directory constraints for \*.out files in the above document?
For example)
1: /home/moco/log/hub/Test.log&nbsp; &nbsp;(&nbsp;Registered )
2:&nbsp;/var/log/Test.log (Registered)
3: /home/moco/log/hub/Test.out&nbsp; (not Registered)
4: /var/log/Test.out (Registered)
**Author:** ![Radoslaw\_Szulgo](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/radoslaw_szulgo/32/1977_2.png) [@Radoslaw\_Szulgo](https://community.dynatrace.com/u/Radoslaw_Szulgo)\
**Post date:** [June 2, 2021, 8:16am UTC](https://community.dynatrace.com/t/questions-about-log-monitoring-constraints/31660/2 "2021-06-02T08:16:21Z")
</div>
It’s just a convention we use to not push all text files into the log ingest. Some may be outputs of a script and not necessary a traditional log file. We believe it’s safer to add what we are sure of and leave to user a decision to add more, rather than automatically push too much.
