Release number in the product ?
where do we find the release number in the installed product ?
Thx
The package file that is downloaded for Windows and Linux will have the release number of the sort 1.111.203. The second part of that the 111 is the agent release number.
You can find it when you download package / shell script from Deploy Dynatrace.
Thanks :slightly_smiling_face:
In addition, you can see which version of the OneAgent is installed on a particular host. Go to the host, click “Edit” at the top, then go to “Updates”. Here you can see the currently installed agent version and verify that it’s up to date.
Hi, thanks to both of you for your answers. Concerning the product, not only the agent, is it possible to see the version somewhere, once the product has been installed, ie we don’t necessarily the package files anymore ?
It’s in the right user menu at the bottom
