Couldn’t found this in the github page. So… thought I better ask here.
Upper ring of UFO got blue light rotating clockwise, bottom ring of UFO got blue light rotating anti-clockwise
It APPEARS TO BE not able to connect to Wifi. (But I am not quite sure, nothing written in the documentation of the Github page)
Blue flashing means it is in ad hoc mode - you can connect to the UFO directly to configure it (connect to the UFO wlan and open http://192.168.4.1)
Also, if you are trying to connect to a SaaS tenant, try using just the environment ID when configuring the device
@Wai Keat C. I spent months getting the UFO’s to work here at our organization, I have made a PDF document on how to get it to connect. The two blue rings rotating states that the system is connected to a WIFI signal but is “searching” for a Dynatrace tenant/environment to access. At that point you will need to ensure you have a Token created for the host as well as a public activegate within the DMZ. I have added the PDF on how to set up the UFO. Please let me know if you need any other assistance!
setting-up-the-ufo-managed-via-activegate.pdf (341 KB)
