Ruxitagentjs is blocked
Hi Folks,
How can we identify why the ruxitagentjs is blocked? Could be a desktop security protection tool? I have only a screenshot from the client nothing else…
Thanks in advance.
János
@Mizső
I would have them extract the HAR file to send along to support, but also I recommend using the OneAgent health checker.
Which will help you collect the needed information for support:
This allows the support team to detect what host/process is serving up the injection and will help identify the blocking in conjunction with the supplied HAR file.
Hi @ChadTurner ,
Thanks, I am going to check it.
Best regards,
János
@Mizső,
Beware, some browser extensions block ruxitagentjs*
yeah I’ve seen “uBlock Origin” extension blocking the RUM agent JS by default (the default block lists include most monitoring agents).  If it’s for internal users, get the IT/desktop whichever team maintains the SOE/browser config to deploy an allow list for your internal URIs.
Nothing you can do for external/public users if they have extensions blocking things.
Hi Folks,
It was “uBlock Origin”…
Thanks for your help.
Best regards,
János
For systems you can control…
I’ve put together this allowlist config for uBlock Origin.  This allows the agent script on any site.
!Dynatrace RUM agent<br>@@||/ruxitagentjs_*.js$script
Yep, great! Have been using it also, and it’s ancestors for more than a decade now :grin:
Hi @cvdewr,
Thanks for sharing it. I have already passed to my client.
Best regards,
János
