I’m the only user in my SaaS account. Still a lot of features give me error that I don’t have access to view logs, create memory dumps, cannot create request attribute. This was working fine sometime back when I last used these features. Anyone else is facing this?
As an admin you shoudl have access to everything. Go into the settings and check your user account. Ensure that you have a check marks for each option on each environment:
If you dont, Go into the Group Management, search for the Out of the box group called “Monitoring Admin” and then select the environment and assign the rights to the entire environment as desired:
okay so that image is at your user level. Can you go to the group and give those rights to the grouping that you are part of (See my second image i sent)? do you run into an error? If you do, you can always create a new grouping and give yourself admin access/all rights and add yourself to the group as needed
Sorry didn’t understand the 2nd paragraph initially. Was able to edit the Monitoring Admin Group. Its working now. Thank you for your help.
