Is there any way to save and rerun an advanced log query. I tried saving the URL and re-running the next day - says it’s not valid anymore.
I have several Splunk and Dynatrace queries that I run daily. I have the Splunk queries saved into a .bat / .cmd file.
I’d like to add the Dynatrace log queries to that file.
Is that possible?
I don’t have an answer to your question, but I do have some suggestions 🙂.
If you’re creating a report from the results of that advanced log query, I suggest using a workflow to run those queries and generate an email.
If you’re just running a bunch of queries to view results en masse, you can use a shared notebook (or dashboard) and run all with one button.
You can create a Notebook where query output information is frozen until you execute it again.
Best regards
