# Separate problems open for each service
**URL:** <https://community.dynatrace.com/t/separate-problems-open-for-each-service/38170>\
**Category:** Open Q&A\
**Tags:** problem-detection, services-classic, problems-classic\
**Created:** [January 26, 2023, 7:47pm UTC](https://community.dynatrace.com/t/separate-problems-open-for-each-service/38170 "2023-01-26T19:47:33Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![jarinmusarrat](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/jarinmusarrat/32/13318_2.png) [@jarinmusarrat](https://community.dynatrace.com/u/jarinmusarrat)\
**Post date:** [January 26, 2023, 7:47pm UTC](https://community.dynatrace.com/t/separate-problems-open-for-each-service/38170/1 "2023-01-26T19:47:33Z")
</div>
Hello team, Dynatrace merges the service problems with same root cause. But is there a way to have separate problems open for each of those services?&nbsp;Thanks.
**Author:** ![ChadTurner](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/chadturner/32/161_2.png) [@ChadTurner](https://community.dynatrace.com/u/ChadTurner)\
**Post date:** [January 26, 2023, 7:59pm UTC](https://community.dynatrace.com/t/separate-problems-open-for-each-service/38170/2 "2023-01-26T19:59:29Z")
</div>
I dont think that is possible as Dynatrace will join related problems into the same problem id. But would be a great RFE to put in.
**Post date:** [January 26, 2023, 8:00pm UTC](https://community.dynatrace.com/t/separate-problems-open-for-each-service/38170/3 "2023-01-26T20:00:38Z")
</div>
Thank you Chad I’ll suggest the customer.
