# ServiceNow Integration - how to handle the Multiple Infrastructure Problems?
**URL:** <https://community.dynatrace.com/t/servicenow-integration-how-to-handle-the-multiple-infrastructure-problems/36520>\
**Category:** Open Q&A\
**Tags:** problem-notification, tagging, davis, servicenow\
**Created:** [September 13, 2022, 7:19pm UTC](https://community.dynatrace.com/t/servicenow-integration-how-to-handle-the-multiple-infrastructure-problems/36520 "2022-09-13T19:19:10Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![shakib](https://avatars.discourse-cdn.com/v4/letter/s/4491bb/32.png) [@shakib](https://community.dynatrace.com/u/shakib)\
**Post date:** [September 13, 2022, 7:19pm UTC](https://community.dynatrace.com/t/servicenow-integration-how-to-handle-the-multiple-infrastructure-problems/36520/1 "2022-09-13T19:19:10Z")
</div>
I was wondering how others are handling the following scenario.
For the most part, when there is a problem identified by Dynatrace, it’s on a single service or host or process/group. And via our ServiceNow integration, an incident is created with a single CI referenced.
However, when there is a problem impacting multiple hosts that Davis AI compounds into one single problem alert (a multiple infrastructure problem), which then reports multiple hosts to ServiceNow.
Here is how such a problem looks in Dynatrace referencing 2 hosts.
 ![shakib_1-1663096634075.png](https://global.discourse-cdn.com/dynatrace/original/2X/5/5d09bb61c0897834faf75cef3ca73fadb3da6ec0.png)
Here is how that’s being reported in ServiceNow, reporting both hosts.
 ![shakib_0-1663096597473.png](https://global.discourse-cdn.com/dynatrace/original/2X/5/5bdba585bf967c3734cae8601ebe9a8bcba34112.png)
In ServiceNow you can only have one assignment group. If more than 1 host get reported, it could be tricky deciding to whom the ServiceNow incident should be assigned. Has anyone else come across this? How did you solve for this?
**Author:** ![DarshanaR](https://avatars.discourse-cdn.com/v4/letter/d/b19c9b/32.png) [@DarshanaR](https://community.dynatrace.com/u/DarshanaR)\
**Post date:** [September 27, 2022, 6:19am UTC](https://community.dynatrace.com/t/servicenow-integration-how-to-handle-the-multiple-infrastructure-problems/36520/2 "2022-09-27T06:19:18Z")
</div>
Hi Shakib,
ITOM integration can help here where each event in a problem is pushed to service now event table.&nbsp;
For these events, rules can be configured in SNOW to create incidents.
Regards
-Darshana
