You might need to get support involved in this so they can strip out the built in rules for your application, but you can always set the User Action Placeholder you want to capture:
currently there is only a workaround to achieve this.
you can add an action property that “tags” your action and then use this action property to filter for the ones with a tag value of “SLA” in the MDA. This works since we provide a “contains” filter for action properties. And it works with creating metrics!
I had thought of this trick - but unfortunately I cannot set the Action Property by the action’s name
If there was a way of marking actions name XYZ with a Property Called X - this could have worked…
