Siteminder monitoring
is there a way to monitor Siteminder with Dynatrace? Is this technology supported?
Its worth a shot to try out. if you cant use the Oneagent on it, you can always monitor it via angentless.
most of site minder is just java. We use the one agent to monitor. you can also enhance with extracting JMX metrics.
if your dealing with the SMPolicy servers, Please note that it is extremely important to load test this. Extracting metrics can lead to exponential performance impacts.
Thanks for the comments Peter! I’m also about to implement some monitoring for Siteminder in the future, so this is good stuff to know.
Peter,
I know this is possible but can you provide a little more details, instructions, steps or anything that can help please?
