Slowest 10% and Slowest 5% - Dynatrace SaaS
In dynatrace SaaS, for the response time graph noticed that “Median, slowest 10% and Slowest 5%” .Please help me to understand how these 3 are calculated , if we switch over we can see left side in y axis(response time) changing . Thanks in advance!
Soorya Mohan
Thanks Andi!! I will check in that forum!!
Median - Is the 50th percentile value.
Slowest 10% - Is the 10th percentile value.
Slowest 5% - Is the 95th percentile value.
These values are for the period one gets while the hover on the graph.
I think you had a typo. Here’s the correct understanding:
Median - 50th Percentile Value
Slowest 10% - 90th Percentile Value
Slowest 5% - 95th Percentile Value
Hi Joshua,
Thanks for correcting, yes Median would separate the higher half with the lower half.
Akshay
