Specify Duration Time Literals When Parsing JSON with DQL
Hello, I am attempting to parse the following json:
{"ResultCode": "Ok",
"DurationMs": "450.1132",
"PerformanceBucket": "250ms-500ms"}
I use the following DQL in my notebook:
fetch logs
| parse content, "JSON{STRING:ResultCode, STRING:PerformanceBucket, DURATION:DurationMs}:parsedContent"
How can I specify that the Duration is in milliseconds instead of nanoseconds (which is the default)? It looks like the DURATION datatype doesn’t allow to pass a duration time literals argument…
DQL data types - Dynatrace Docs
can you add in mathematical operators to take your nano and multiply it by 1,000,000?
nanoseconds = (5 ms × 1,000,000) = 5,000,000 ns
