could not find a built in metric so decided to build this one.
Is this unbelievably basic thing in a tool the is used for observability not supported?
any other way to display this clearly in a dashboard?
Thank you
Do you need “Merge services”? Can you try it with “Split by Services” as split mode?
Best regards
I would, Sadly there are too many results that way that are well above the 100 limit.
You can create more than 100 dimensions in new metrics if necessary
Product idea has been raised.
