How can i see a view statement in dynatrace?
I am not sure if you are asking about this, but you have top database statements in Dynatrace.
Best regards
but i cant see the âviewâ statement there
Please review:
Bind variable settings for DPS and Adaptive traffic management Version 3
Application Observability | Distributed traces
Bind variable capturing can be enabled by all accounts using a Dynatrace platform subscription and tenants that are using Adaptive Traffic Management V3. No additional support request is needed.
Hi @natanael_mendes ,
What exactly do you mean by the âviewâ statement, or what specific data are you trying to look for? As @AntonPineiro mentioned, most of the information that youâre going to want to be able to analyze is going to be in the top database statements.
Since Dynatrace captures the DB information from the perspective of the application, youâll be able to see specific queries and modifications as well in the âDatabaseâ section of Dynatrace as well.
Drilling down into this might give you further insight into what youâre trying to look for.
Cheers,
Taylor S.
