SSL Certificate Monitor extension add certificates to MZ
Hi Folks,
Issue: If you use SSL Certificate Monitor plugin and your hosts or hostgroups are organized in MZ and you filter to your MZ on your hosts overview pages you can not see the certifiactes belong to the host or host’s processes.
How to add certifiactes to the MZs? Organize your certificates configurations by host groups or MZ. Configuartion_label will be important in my case.
Add your certifacte to the proper MZ with entity selector:
type(python:certificate_monitor_certificate),monitoring_config(YYYY) - Now I am using this. Configuration_label = monitoring_config (property of the certificate see below)
OR you can use other certificate properties:
type(python:certificate_monitor_certificate),port(5556)
type(python:certificate_monitor_certificate),subject_alt_name_1(weblogic)
You can check your certificate properites with the monitored etities API call with entity ID:
GETSaaShttps://{your-environment-id}.live.dynatrace.com/api/v2/entities/{entityId}
Environment ActiveGateCluster ActiveGatehttps://{your-activegate-domain}:9999/e/{your-environment-id}/api/v2/entities/{entityId}
Example response:
“entityId”: “CUSTOM_DEVICE-5C8A7360EA322B7E”,
“type”: “python:certificate_monitor_certificate”,
“displayName”: “weblogic certificate on 5556”,
“firstSeenTms”: 1700783563328,
“lastSeenTms”: 1723801132413,
“properties”: {
“subject_alt_name_9”: “”,
“subject_alt_name_8”: “”,
“subject_alt_name_7”: “”,
“subject_alt_name_6”: “”,
“validity_not_before”: “2022-11-17”,
“subject_alt_name_5”: “”,
“host_port”: “10.240.162.16:5556”,
“subject_alt_name_4”: “”,
“monitoring_config”: “YYYY”,
“subject_alt_name_3”: “”,
“subject_alt_name_2”: “”,
“certificate_stage”: “STAGE_0”,
“subject_alt_name_1”: “weblogic”,
“source”: “OneAgent”,
“subject_common_name”: “weblogic”,
“host_att”: “HOST-80742DFBF49E5399”,
“issuer_org_name”: “XXXXXXXXX”,
“common_name”: “weblogic”,
“cert_lifecycle”: “0: Greater than 30”,
“issuer_common_name”: “XXXXXXXXX”,
“serial_number”: “0xd024d027dd262333c96ced3808de619”,
“port”: “5556”,
“subject_alt_name_10”: “”,
“subject_alt_name_11”: “”,
“subject_org_name”: “XXXXXXXXX”,
“validity_not_after”: “2024-11-17”
“tags”: [],
“managementZones”: [],
“icon”: {
“primaryIconType”: “dynatrace”,
“customIconPath”: “certificate”
“fromRelationships”: {
“runsOn”: [
“id”: “HOST-80742DFBF49E5399”,
“type”: “HOST”
“isChildOf”: [
“id”: “CUSTOM_DEVICE-6AD8A21A0BEE2345”,
“type”: “python:certificate_monitor”
“calls”: [
“id”: “PROCESS_GROUP_INSTANCE-7AFD523F463BE74E”,
“type”: “PROCESS_GROUP_INSTANCE”
I hope it helps.
Best regards,
Mizső
I encountered the same issue indeed. I’m using the MZ config: type(“python:certificate_monitor_certificate”),fromRelationships.runsOn(type(HOST), Tag(“AppA”, “AppB”))
I use this one as I prefer the configuration to be generic and control all entities via autotagging. This way I know all configs on all different places in Dynatrace (MZ’s, Dashboards, etc etc) will point to tagging and if something is wrong I can modify tagging which directly has it effects on all views.
Kind r egards,
Daan
Hi @Daniël
It is also a nice solution. Thanks for sharing it.
Best regards,
Mizső
Hi All,
I’m trying to configure the SSL Certificate Monitor extension using Tag-based filtering.
However, when I select a specific tag, only one host appears, even though multiple hosts have the same tag assigned.
Issue:
  • Tag: SSL Certificate–IMPS: Web
  • Expected: Multiple hosts should show up (all hosts with this tag)
  • Actual: Only one host is displayed for selection
Do we need to enable any additional settings for tag-wise host discovery in the SSL Certificate Monitor?
Hi @Sohel_Rashid
I would create a Management Zone for the tagged hosts and then in this extension configuration I would use the Management Zone tab for the configuration. In your example at the Host tab you can select only one host always, with the tag in this case you can only filter not select hosts.
Example MZ: Certificate.
Example Rule with Entiriy selectror: type(“HOST”),tag(“SSL Certificate–IMPS”)
I hope it helps.
Best regards,
János
Hi János,
Thanks a lot for the clarification.
So, to confirm — I need to create a new Management Zone specifically for this use case. I already have an existing IMPS MZ, but I cannot use the rule:
type(“HOST”), tag(“SSL Certificate–IMPS”)
inside that MZ because it would pull in all hosts with this tag, correct?
Just wanted to confirm that adding this rule inside the existing IMPS MZ will make all tagged hosts appear in that zone.
Thanks again for your support.
Sohel
hi @Mizső,
I have automated the same with adding the tags for entity and assign it to respective MZs.
Pro Tip: Solving the Unsolved - Automating Dynatrace SSL Certificate Monitoring - Dynatrace Community
Have a look and share your thoughts on this. Will share the Workflow if needed too.
Hi @Sohel_Rashid
Yes would create a brand new MZ. I assumed you have already tagged your host, so SSL Certificate–IMPS tag is already existed. With use of this existed SSL Certificate IMPS I would create the new MZ. Maybe there are another more simple solutions with less administration. This was my first idea about it.
Best regards,
János
Hi @AravindhanV,
I have already seen your post. I gave a kudo on 18th of Sept.
Nice solution. My solution can be use at smaller organozations (with click ops) and at gen2 Managed environments where gen3 workflow is not an option.
My clients are mostly still use gen2 Managed in my country. At a new application onboarding process we always create auto tags for the entities in case of certifiacates also and then we build the new MZ based on the tags (including certifiactes).
tag rules for tag_for_mz:
type(host),Entityname.startswith(“beggining_the_host_name_pattern”)  ---- there are others options after the type(host)
type(python:certificate_monitor_certificate),fromRelationship.RunsOn(type(host),tag(“tag_for_mz”))
MZ rules:
type(python:certificate_monitor_certificate),tag(“tag_for_mz”))
Best regards,
János
Ack it :slightly_smiling_face: It depends on the org usage as well. Thanks for responding @Mizső  Cheers
Hi János,
Thank you for the detailed explanation and the example. This clarifies how using a Management Zone with entity selector works better than selecting individual hosts.
I will proceed with this approach and configure it accordingly.
Really appreciate your support.
Best regards,
Sohel Rashid
