Store custom problem notifications data in to SQL server
Hi Team,
Greetings of the day.
I am new to dynatrace.My question is how to store custom problem notifications data in to
sql server database using Dynatrace API.I am unfamiliar with a best way to achieve this.
Please share any recommendations for how to achieve this.
Thanks in advance!
Hi @Koteswar
You should use the Probelm APIv2. You need an API token with probelm.read scope.
Collect the closed custom severity problem ids for the last day (-1d):
curl -X GET https://your_environment/api/v2/problems?from=-1d&problemSelector=severityLevel%28%22CUSTOM_ALERT%22%29%2Cstatus%28%22closed%22%29 -H “accept: application/json; charset=utf-8” -H "Authorization: Api-Token YOUR TOKEN
Use the collected problem ids (bold in the middle is an individual prolem id), then you will receive the details of this individual problem.
curl -X GET https:// your_environment/api/v2/problems/-7695485534087673753_1669185960000V2 -H “accept: application/json; charset=utf-8” -H “Authorization: Api-Token YOUR TOKEN”
I have already attached a sample response from an individual custom problem.
I hope it helps to start build your process.
Best regards,
Mizső
response_1669207438538.zip (833 Bytes)
@MizsőThank you for quick response. Yes the above information is helpful but my specific requirement is automatically to save problem notification(log) data to sql server for further investigation. Please advise on this.
Thanks in advance!
Hi @Koteswar,
I think there is not other way to pull problem data from DT. You should build your auto process for this procedure.
Best regards,
Mizső
Hi @Mizső thank you for sharing the information.
Please advise on my second question, I have created alerting profile and linked with email alert notification. Test email is triggering and receiving email alert successfully but when the problem has notified in Dynatrace, email alert is not triggering.
Many Thanks.
Hi @Koteswar
For automate this procedure you can build ActiveGate extension
HTH
Yos
