SUN Solaris and OneAgent Services Status
Dear All,
How to check the status of OneAgent services running on the SUN Solaris?
How to start/stop/restart the service on the SUN Solaris?
Babar
On Solaris, the OneAgent is not installed in a ā€œFull Stackā€ manner where you install the agent and it does everything automatically. You basically unzip the agent binaries and reference them as library files from the instrumented applications. This means there actually are no OneAgent services to stop or start like there are on other architectures.
Hello @Dave M.
We are aware of the installation processes as 90% infrastructure based on the SUN Solaris. I was just wondering that might be there is a way to know the status but it means it depends on the instrumented services.
Babar
