Synchronization with Monaco: Excluding Specific Settings or Dashboards
With the monaco download, monaco deploy, or other monaco commands, is it possible to specify settings or dashboards to exclude from synchronization? For instance, imagine a dashboard is merely a Proof of Concept (POC) or playground in the development environment, and we prefer not to see it synchronized in the production environment.
Yes it’s possible. The skip field makes it possible to omit (skip) deployment of a certain configuration. If skip is set to true, the Dynatrace Monaco CLI will not deploy the configuration.
More information down below:
https://docs.dynatrace.com/docs/manage/configuration-as-code/monaco/configuration/yaml-configuration#skip
