Temenos T24 Transact Users Activity Monitoring NG|SCREENER
Dear all,
A customer has the NG|SCREENER tool to monitor the user’s activity accessing the Temenos T24 Transact servers.
How can we achieve the same or better using the Dynatrace?
It is a kind of audit of those activities performed by respective users.
Initially, the user logs in to the NG|SCREENER tool first and then accesses the Temenos T24 Transact server.
Babar
@Babar_Qayyum - im not too familiar with that tool but Dynatrace offers Audit logs from the API but also via a Services/Elevate Portal
Hi @Babar_Qayyum
If the Temenos T24 servers are monitored in Dynatrace in Full-stack mode so you will be able to detect the full transactions of user activity as the user after passing  NG|SCREE, and when performing backtrace you will observe it comes from unknown host.
Via Temenos T24, kindly consider creating a request attribute to fetch the email value for each user.
Also:
  • Monitoring the logging logs will be an added value for extended level of visibility.
  • Monitoring NG|SCREENER will figure out the actual transactions path from start to end.
  • Ingesting Logs into Dynatrace in case NG|SCREENER monitoring is not an option.
Hoping it adds value.
BR,
Peter.
Hello @Peter_Youssef & @ChadTurner
I appreciate your feedback. I will explore these options further.
Babar
