# Total disk metrics
**URL:** <https://community.dynatrace.com/t/total-disk-metrics/38951>\
**Category:** Dynatrace API\
**Tags:** dynatrace-managed\
**Created:** [March 22, 2023, 12:09pm UTC](https://community.dynatrace.com/t/total-disk-metrics/38951 "2023-03-22T12:09:55Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![RituSingh](https://avatars.discourse-cdn.com/v4/letter/r/ac91a4/32.png) [@RituSingh](https://community.dynatrace.com/u/RituSingh)\
**Post date:** [March 22, 2023, 12:09pm UTC](https://community.dynatrace.com/t/total-disk-metrics/38951/1 "2023-03-22T12:09:55Z")
</div>
How to fetch total Disk capacity from Dynatrace API calls, is there any other than deriving it from used and free metrics (or free% and free amount metrics)?
**Author:** ![dannemca](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/dannemca/32/7215_2.png) [@dannemca](https://community.dynatrace.com/u/dannemca)\
**Post date:** [March 22, 2023, 12:40pm UTC](https://community.dynatrace.com/t/total-disk-metrics/38951/2 "2023-03-22T12:40:01Z")
</div>
Hi [@RituSingh](https://community.dynatrace.com/user/60972) , good day.
Did you tried the Disk Analytics extension? [Disk Analytics extension — Dynatrace Docs](https://www.dynatrace.com/support/help/platform-modules/infrastructure-monitoring/hosts/monitoring/host-monitoring/disk-analytics)
With this extension, you can use the metric com.dynatrace.extension.disk-devices.disk.size that will provides you the total disk capacity.
**Author:** ![AntonPineiro](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/antonpineiro/32/49_2.png) [@AntonPineiro](https://community.dynatrace.com/u/AntonPineiro)\
**Post date:** [March 22, 2023, 1:38pm UTC](https://community.dynatrace.com/t/total-disk-metrics/38951/3 "2023-03-22T13:38:22Z")
</div>
You can use&nbsp;[API Metrics v2](https://www.dynatrace.com/support/help/shortlink/api-metrics-v2-get-all)&nbsp;to get that information.
Disk total =&nbsp;builtin:host.disk.used +&nbsp;builtin:host.disk.avail
Best regards
