Situation: a Managed environment of >5 nodes, with internal DNS “dynatrace.customer.org”
When on some cluster nodes the setting “Web UI traffic” is set to “disabled”, they still receive UI traffic.
Is this expected? Maybe this option only works with an automatically provisioned domain (xyz.dynatrace-managed.com)?
As stated in Set up a load balancer for Dynatrace Managed — Dynatrace Managed Docs
“… In the Cluster Management Console, you can exclude a node from web UI traffic. This feature affects the NGINX configuration and the automatically provisioned domain (xyz.dynatrace-managed.com). When you use an external load balancer, cluster nodes need to be excluded from the list of target nodes; otherwise, they will still receive network traffic”
