HI,
I want to make agent version upgrade filter by management zone and version , how i can make it?
Thank you a lot
Elisa Gaiti
HI,
Thank you a lot
Elisa Gaiti
Hi Chad,
thank you can you please explain me with step the operation that i can do?
I arrived to the step but i don’t found the step update.
Than you
Elisa Gaiti
Ahh, I apologize, I misread that. You can only upgrade hosts by Host Groups or 1 by 1. There is no option to update all hosts in a given Management Zone. My recommendation is to set your Management Zone and reviews the Host Groups included in the Management Zone. Then take those Host Groups and update them.
