I’ll briefly summarize the Community thread that @AntonPineiro shared, as it answers most of your questions.
Based on the current guidance from Dynatrace and the community:
For Dynatrace Managed, there isn’t a dedicated UI indicator confirming that the Python runtime upgrade completed successfully (unlike in SaaS). However, you can validate it by checking the dsfm:extension.engine.python_configs.running metric (available for Python-based extensions on OneAgent/ActiveGate 1.333+) and by verifying that your extensions continue to execute successfully after the upgrade.
Regarding rollback, I couldn’t find any officially supported rollback procedure. Since the Python runtime is bundled with the OneAgent/ActiveGate version, rolling it back would require downgrading the corresponding OneAgent/ActiveGate version, which is generally not recommended unless advised by Dynatrace Support.
One additional note from the Dynatrace product team: starting with OneAgent/ActiveGate 1.333, extensions that support the newer Python runtime will use it automatically. Extensions that are not compatible with the newer runtime will eventually stop working once the environment migrates, so keeping extensions up to date is recommended.
Hopefully this helps until Support provides more specific guidance for your Managed environment.
