View Oracle ASM disk performance
is there a way in Dynatrace to view Oracle ASM disk performance? We are gathering some Oracle information via custom scripts into Dynatrace for other Oracle metrics, but I am asking if there is anything easier.
Any help is appreciated.
Lou
The Oracle extension fetches that information if you check the ASM feature set. https://www.dynatrace.com/hub/detail/oracle-database
