View Sensitive Data and ORA-***** exceptions
We don’t want to give View Sensitive Data rights to everyone …
But we do want everyone to be able to analyse exceptions. Often we have Oracle exceptions which nicely indicate the number ORA-******, but without View Sensitive Data rights this masked.
Is there a way to configure this in a way that we can grant everyone the right to see all exceptions without masking?
If not possible, I would suggest an RFE to make some kind of exclusion for these ORA- numbers. They are never sensitive.
Hi @Bert_VanderHeyd
I haven’t come across this feature yet. May be if we can try the access policy this can be achieved. I should give it a try myself to be sure.
Hello.
Are you sure this information is not available to you due to restrictions?
If we are talking about the error analysis level - each exact ORA- * error number can be looked at at the PurePath level (Trace level in “Error” tab)
You can drill down to PurePath and get exactly ORA error number without “*”
Romanenkov Alex
I have to ask. Since I have all rights I can’t verify that myself.
Although I am wondering what the benefit is of this approach. If the details can be found at trace level anyway - unmasked - what’s the point of masking them in the Failure Analysis screen?
Dear Alex,
ORA number is not available in the purepaths:
Kind regards,
Jérôme
Hello. I’ve come accross with the same issue. Does anyone know why we see masked data in requests, while the user has “view sensitive data” permissions?
Thanks.
