View Web Service request values
I am new to Dynatrace Product. I need some guidance on how to see the values of a web service request.
The Web Service application is running on IBM HTTP server / Websphere, we can see all the methods, but when we tried to view the request values via purepath it stops at the method.
Troubleshooting an issue with a error is tough when you can’t see the related data.
Dynatrace Managed Solution 1.136.143.xxxx with Dynatrace OneAgent 1.135.11.xxxx
Any advice is greatly appreciated.
MRC
Hey @Venkata C. can you post a screenshot of what area you’re seeing this in/trying to get to?
Hello @Rocky O. I am not in a position to post a screenshot that you requested. Under Transaction and Services → monitored web service → Details → PurePaths → PurePath (Code Level)
I see methods that are used in the web services but not the pay load.
Thank you for looking into my request!
If I understand your question correctly, you need to capture method arguments for a method that is called in a PurePath.
Dynatrace does not capture arguments by default, but you can setup that. It is configured in Settings → Server-side service monitoring → Request attributes.
But you can capture only Text/Int/Double types.
Useful info is in this blog post: eBook: Java enterprise performance
Thank you! I will test it out before our trial expires :wink:
