For some reason, every 2h, some volumes in some of the VM datastores, are losing their connection, due to IOPS. Can anyone explain me how I can find the rootcause for it?
Is there a process that is running every two hours that is having a high Demand in IOPS? Your using Dynatrace Managed, So I’m Assuming that your AG’s are also VMware? It could be that the IPOS is affecting the AG that is pulling the data and if the pull fails then it wont go back and try to repull the failed data.
