One of my synthetic is failing on the last event. I’m keen to investigate the reason but there is no waterfall analysis available. Is that due to last page?
Please assist.
Munawar
Can you please send us the configuration of this step?
Radek
Hi Munawar,
If you are talking about the waterfall analysis of the last action which broke the scenario, most probably it will not show as the action is not completed. but you can check the failure reason and details from the trial itself.
Islam
Yes, exactly this. It depends on why the monitor is failing on that event. For instance, if it is due to not finding the locators then you will need to check the event prior to see what happened. Sometimes it is even earlier in the scenario if there is no validation added.
