WebHooks injestion in Dynatrace
Dear Community,
I hope this message finds you well. I am reaching out to seek assistance on a project that involves the integration of UIPATH Webhooks with Dynatrace.
Specifically, we are looking to establish a seamless integration wherein UIPATH sends webhooks to Dynatrace, allowing us to monitor the execution of UIPATH processes in real time and gain insights into their performance metrics.
Is there a way that we can achieve it, we have tried using the dynatrace API but there is a kind of mismatch betwen the payload sent in the webhook and the one accepted by Dynatrace
thanks,
Andrea
Hello @andreaCaria could you provide us further details about what Dynatrace API are you using and the payload from UIPATH?
payload problems could be related to a lot of reasons, invalid chars or formats, missing escape characters among others.
Hi @DanielS thank for the answer,
the API that we have used is:
.live.dynatrace.com/api/v2/metrics/ingest
and there are described all the possible types of webhooks sended from UiPath:
Besides the technical issue, I’m more interested in understanding if this can be done and if it is the correct workflow because in the documentation we did not find any guide that allows us to convert an incoming webhook in a metric directly in dynatrace.
Ok, understood, if you want to send the payload that UIPATH produce according to the link you shared, and insert it into Dynatrace using the metrics API one to one, this cannot be done. But what could be done is, to parse the output JSON from UIPATH and ingest into Dynatrace the number of jobs started or failed. You can use that number as a metric value for example. Remember that you can specify a payload in two formats: gauge (gauge) or count value (count).
For more info about this, please refer to Metric ingestion protocol — Dynatrace Docs
Thanks a lot @DanielS , do you think it is possible to workarround this problem by means of some dynatrace features such as extension or app functions?
Does anyone face this problem before?
Yes, I think it is possible. Personally and based on your presented case I prefer to go with a script parsing the output from UIPATH and then ingest the metrics you need into Dynatrace based on your needs.
I already face this problem, not with UIPATH but with other integrations.
Buenos Dias Andrea,
Te escribo dado que actualmente requiero hacer una integracion con UiPath para realizar lo mismo que tu, tu me puedes brindar que se necesita por parte del Uipath y Dynatrace para configurar esto de manera satisfactoria.
Edited because this forum is in English
Good morning, Andrea,
I’m writing because I currently need to integrate with UiPath to do the same thing you did. Can you tell me what UiPath and Dynatrace require to successfully configure this?
