I am trying to integrate OneAgent with our company Active Directory. I need to know what protocol does Dynatrace use (SAML, WS0Fed or OAuth)?
Hi @Shikha Y.
I’m not sure what your use case is. Do you want to use your company credentials to login to Dynatrace?
Gerald
The intention is to identify users in ‘User Session’ by company ID.
Doing this for each application separately using user tags will be tedious and non uniform.
The only way to tag User Session with a name/id is by defining them for the application, or using the JavaScript agent API to call drum.identityUser()
