What is the best way to create daily report from application logger
I need to create a report out of application log and need to send the data to business team daily. Is there any way to create tabular form report and email it to a DL ?
Hi @susmita_k ,Do you have Grail enabled?
yes..
I would say combination of Workflow + Notebook.
Best regards
How do we create tabular format report using Workflow ..? when you say notebook, you mean using the grail query ?
I do not know what do you mean with tabular format but Notebooks are here.
You can find examples in playground tenant.
Best regards
