When does an entity (process, services ) go from “last call X minutes ago” to “offline for X minutes” ?
Best regards,
Fousseyni B.
Best regards,
Fousseyni B.
Last call… means that the entity is available but was not called since the specified time.
Offline for… means that the entity is not available/offline since the specified time.
Does offline mean a process or a service is not monitored ? Or aprocess or a service is stopped ?
Best Regards,
Fousseyni B.
You can check the availability section of the process to see if it was running, shutdown (gracefully or not) or unmonitored:
I’m not 100% sure if the same states are reflected in the status for the under the process/service name or if it always shows offline if not available regardless of the reason.
