When ALR is activated, I understand the number PurePath captured will be reduced.
How about metrics? (especailly Throughput. CPU & REsponse TIme & Failure Rate I didn’t really interested that much.) Will be make the throughput in the chart lower than it actually is?
I am running a load test now with 10k concurrency, it happens that right now ALR is activated and I see that the throughput at the service there is only 3k. So, want to know if it is only some load testing scripting issue causing this? or also ALR is playing a part in here as well.
Best Regards,
Wai Keat
