Where the "Always On" metrics are located?
Hi everyone,
Two days ago I installed the SQL Server extension to display my Always On availability groups. So far I only see the SQL Server metrics in the Data Explorer but not the Always On metrics. Does anyone know where this data could be located?
Thanks in advance
At this time you can view the metrics via Dashboard. Under Dashboard look for SQL and you would find Dynatrace Dashboard generated which gives you all the data or from the Hub where you created the end points you would see additional details on the page explaining about the metrics etc you would find a link.
Our understanding is enhancements are on the way that would put everything together
