If I go to JBoss process dashboard → Further Details → Web Request → the dashboard is empty.
Root Cause:
By the default, the JBoss EAP has no statistics enabled.
Solution:
The WebRequest Metric can be enabled by the WebGui or Config.
WebGui:
Config:
Example:
<subsystem xmlns="urn:jboss:domain:undertow:7.0" <span class="">default</span>-<span class="">server</span>="default-server" <span class="">default</span>-virtual-host="default-host" <span class="">default</span>-servlet-container="default" <span class="">default</span>-<span class="">security</span>-<span class="">domain</span>="other" <span class="">statistics</span>-enabled="true">
