Why is my vertical topology missing?
Vertical topology depends on additional information provided by OneAgent. If OneAgent isn’t installed, Dynatrace can’t report details on the vertical topology.
If OTLP requests aren’t routed via OneAgent (implicitly via automatic ingestion or explicitly via an OTLP export to EEC), make sure you manually enrich your requests with the information from the enrichment files.
Great :+1:
