Wrong char in request attribute
I’ve just created a request attribute to extract part of a web request URL. The configuration is as included in the attached file.
A example of request is: /Servicios/AppMobile/LoginUsuarioXML.aspx/LoginUserV2
But when I check the results, a question mark (?) is included in the request attribute and I don’t know why:
Am I doing something wrong?
Thank you.
Hi Damian,
Have you tested using “Web request URL path” request attribute source instead of “Web request URL”? Do you get the same result?
Elena.
Hi @DamianG
try the attached example
it should get what’s before “?”
Hi Damian
Looks like the original request includes that character.
Hi Elena,
I tried using “Web request URL path”, as suggested, and worked fine.
Thank you. Gracias!
Damián
