When looking in AG/OA configs, I notice that the list in the config file with all cluster addresses contains multiple addresses from one specific node. Those extra addresses are unreachable. So all nodes show a single address but one node shows all addresses (including interfaces like backup an management lan)
Can I regenerate this info? Where can I find it on my cluster?
KR Henk
Did you try to set it in CMC for the particular node?
Ok then check what do you have on the embedded ActiveGate on the node. So open security-Gateway/config/custom.properties and in your case might want to add:
[connectivity]
dnsEntryPoint = https://161.89.179.16:8443/communication
and restart the embedded activegate using launcher/security-gateway.sh restart
That’s OK and intended. Usually, multiple addresses are created. OneAgent just uses the first one on the list that works. No problem with that.
We have 1 address per cluster node, one node differs and has all interfaces in the defined in the list.
But you are right, it still functions (-;
