10 Nov 2017 08:22 PM
Hi
Is it possible to setup the following alerts with Dynatrace SaaS:
- Request per minute: Sometimes response times might be fine, but request per minute can be low. Is it possible to set alerts. For example, normally request per minute is 1000 and suddenly it got dropped to 100 per min
- Maximum response time: Is it possible to setup custom alert for requests that is taking more than lets say 10 mins. I.e as soon as any request response time is over 10 minutes, send alert.
Thanks.
Best regards
Farid
13 Nov 2017 08:22 AM
Hi Farid,
Its possible to set up a 'Custom alert' within Settings - Anomaly detection - Custom alert. Unfortunately we did not expose the load metric so far, but you set a threshold and alert on the response time. Load will follow within the next weeks.
best,
Wolfgang
