Alerting
Azure Key Vault monitoring - Alert on secret failure
DStockland
Participant
My team is working to integrate AKV with Dynatrace.  We have the implementation configured and are seeing metrics on the key vault itself.  I know I can set alerting for backend services, app pool failures, synthetics etc... but, I was curious if anyone knows if there's a way to alert when pulling a secret fails.  Trying to get as many hooks in as I can.  First time performing this type of integration.
Any help is appreciated and I'd be happy to share any extra info you all may have.
DS
GosiaMurawska
Community Team
Community Team
Hi @DStockland, did you manage to work this out? It would be great if you share it with the Community 🙂
Hi @GosiaMurawska!  I'm not 100% sure this is the correct solution, but what we did was we synchronized with the external vault (https://docs.dynatrace.com/docs/observe/digital-experience/synthetic-monitoring/general-information/...).  This in turn creates a http monitor between Dynatrace and Azure Key Vault.  If DT fails to update its secrets, we send out an alert.
We also looked into creating a custom alert that looked at the AKV service, but there is not enough verbose info coming from the application that could make a solid determination (at this time) that it failed to pull a secret.
Hope this helps!
