07 Nov 2024 08:05 AM
TCP connectivity rate for process org.apache.activemq.artemis.boot.Artemis gp-prod-cluster-ss-* has decreased
but we did not find any connections error for that certain time being on OCP node and Pod level. and this alert is triggering often how to deal with this problem.
12 Nov 2024 10:06 AM
@Jivan - Do you see any process or pod restarts happening at this time ?
Can you also check if the pod has enough resources to handle the requests ?
13 Nov 2024 11:15 AM
Hello @Jivan
It depends on the current problem triggering method configured under anomaly detection > Hosts either via:
KR,
Peter.
