25 Jun 2019 09:01 PM
Why don't I have the option of defining a rule using "greater than" when I am editing a particular service to add a custom error using a request attribute? According to this documentation I should be able to choose "greater than" as an option.
25 Jun 2019 09:05 PM
Is your request attribute configured as numeric (integer for example)? If not this may be reason
25 Jun 2019 09:16 PM
@Sebastian K. Yes. 😞 I was hoping to create a custom error when the amount of requests reached a certain threshold.
25 Jun 2019 10:25 PM
I don't have any problems seeing "Greater than" option when defining a custom Error on a service.
To reproduce:
Select the service, -> Edit
Select Error Detection
Select Add Custom Error Rule
If I select a source thats defined to be a string, I don't get the "Greater Than' option. But if the source is defined to be Integer, the "Greater than" shows up.
But I"m not sure this is what you want. It sounds like you want to trigger on the quantity of transactions, not the value of a given transactions request parameter. Or does the Request Attribute contain the trigger value?
27 Jun 2019 08:42 PM
@Joseph M. H. yeah I was hopping to create a trigger if the quantity of transactions is greater than x (amount).
What I'm looking at is identifying Bot traffic - which I've done via request attribute. Now I'm trying to figure out the trend so I can establish a baseline to create a custom error event.
